BigShed
At the art show on Sunday a lady asked whether I could make my bullet pens as a fountain pen.
After initially answering no, she asked me whether I could add a rifle clip to a Baron or Jr Gent fountain pen I had on display.
I thought I might be able to do that with a Baron and promised her I would have a go (as you do!)
When I started measuring the Baron I felt that the slimline rifle clip would create problems with that kit and I started looking through the other FP kits I had to hand.
The Executive fountain pen looked promising, but again the finial end was rather large.
I then had a brain f*rt and thought that a 308 primer end might be worth a crack.
Cut the primer end off, drilled a 1/4" hole (same as inside of slimline tube) recessed the end and milled a slot to take the rifle clip. That looked promising, but I didn't like the slimline finial cap on top of that, looked out of place.
So, got out some 10mm brass rod, turned a 1/4" spigot on the end, parted off and turned a curved end to make a solid brass cap (first time I have done curved ends on my metal lathe, woohoo!)
So, that looked OK, but now the standard Executive end cap at the other end looked out of place. So repeated the above process, minus the rifle clip and hey presto now we have matching ends.
All that remained now was to glue up a couple of Executive tubes with Red Ironbark (her choice), turn them to size, turn a tenon on end to take the custom caps and assmble the pen.
Here's the end result, a Bitzer Bullet Fountain Pen
