Atrax--Midnight Flames
See more from ed4copies
ed4copies
Local Chapter Manager
Racine, WI, USA.
Well, I've turned a couple pens again, with my new vision!!
This one is a newly available component set and some material I happened to have in the basement:biggrin::biggrin:
Hope you like---I do.
Comments and critiques welcome:rolleyes::rolleyes:
ed4copies
Racine, WI, USA.
Tim,
Uses the same size bushings as the Jr. Gent series---but it is a "stripped down" version. Very simple and affordable!!
SDB777
Cabot, Arkansas USA
Just took a look at 'em....admittedly for the first time. And I like the pricing you have assigned them.
Question: Is the clip as heavy duty as it looks in all the photo's I've looked at? And what are the tube sizes(seeing if I can use these pieces to turn closed-end, and save some cha-ching)?
Great looking turned pen!
Scott (less expensive = big bonus) B
alphageek
Former Moderator
Green Bay, WI, USA.
Scott - I've not checked the lengths - but the tubes are the same diameter as a Jr Gent. If you go look for my SOYP, I made 2 closed end pens (1JR, 1 Atrax) last weekend using the same mandrel. I havn't done cap closed yet, but you should be good there too.
ed4copies
Racine, WI, USA.
Looks like you have been busy, Gerhard!!!
Your collection of Atrax demonstrates another thing I like about the "family"---the clip ends look extremely similar, so if you have a ballpoint and RB/FTN in your pocket, they match!!!
This is not true of many "families" of pen.
Nicely done sets!! Thanks for showing!!!
ed4copies
Racine, WI, USA.
looking good Ed!
Did you reverse paint?
Phil
No, I rarely paint Phil!!
If SOMEONE is going to screw them up, I HOPE it will be me, so I TRY most of my materials without paint.
This one turned out really well, but the amount that remains on the pen is fairly thick.
Hope this helps others!!:biggrin::biggrin:
