Another stamp
See more from Rick_G
Rick_G
Bothwell, Ontario, Canada.
Since my mold was sized for 2 sierra's I made a second stamp pen. This one is using Christmas themed stamps. I can see I am going to need to make some bigger molds.
Rick_G
I tried stamps before but the ink ran on them. How do you keep that from happening???
Brian
Luck? I hope you mean the black ink they use to cancel the stamps. I try and use stamps that have very little cancel marks on them and the glue I use to stick the stamps to the tube may seal it. I use a glue from Artquest called PPA (perfect paper adhesive). Supposed to be good for artwork so maybe thats it.
TBCbushings
Hampton, Va.
I used CA to seal them and that's what made the ink run.... The stamp itself ran not the stamp ....These were unused stamps...
Brian
PenMan1
Eatonton, Georgia
CA makes both laser color decals and unused stamps "bleed" in my shop, too. The problem is not as pronounced on ink jet decals, but there is some "bleed".
I have found that a coat of clear gloss Modge Podge applied 24 hours before thin CA with no rubbing(lathe running, no rubbing, NO ACCELERATOR) makes an acceptable product. I have ordered PPA, but have not used it as yet.
I hope this helps!
