Thanks for the kind comments, I'm quite pleased with it too.[
Billy, I'm not too worried about tarnishing. The last ones I made with copper have dulled but look good still. As it is acrylic and there is no plating to rub off, who ever gets it can just chuck some Brasso over it to bring it back to life.
Of course, when I took the pic 'just so' it was to show the curve at the joints. This 'curve' was done with the 4th drill bit. Instead of just cutting the copper to length with a hacksaw I drilled through it with a drill that was a bit bigger than the copper. I then filed the acrylic ( left about 5mm too long )with a rough arch shape. With the normal SL tube holding the copper and acrylic in line and held gently in a vice, I warmed up around the joint with a heat gun while gently closing the vice. This forced the acrylic to form itself perfectly with the copper. I allowed it to cool completely before removing from the vice and glueing it up. The squashing takes up most of the 5mm.
The other 3 drill bits were just steps for the tube and refill. I wanted to make sure that I would not taper the copper into the drilled holes so there is a 2mm hole for the front of the refill, a 4mm hole for the body of it and of course a 7mm for the tube.
Easy huh?[
