Ambonya sceptre fountain
See more from Dan Masshardt
Dan Masshardt
Mechanicsburg, PA
I'm pleased. :).
Dan Masshardt
Mechanicsburg, PA
Every blank is different. This was so
Smooth after ca I almost could have just buffed it without any sanding at all. In truth I only took one abrasive sheet to it because I felt like I should.
TonyL
Georgia
Beautiful! I can't believe what you do with tha pens plus. I have it adn mine doesn't come out like yours. I even have the micro wax. Do you like it better than WTF? I was going to try that next.
plano_harry
Plano, TX 75093
I agree with Dan. I find that with the right technique you can quickly lay down 10 to 20 coats (for open grain) of thin CA that is almost ready for MM.
mrrichieboy
Nampa, Idaho
Dan: That is excellent work...you just helped me make a decision. I have a Sceptre Fountain pen sitting on my work bench with 2 blanks next to it...one is Desert Ironwood, the other is an Amboyna Burl blank similar to yours and I've been waffling about which on to use....looks likes it's the Amboyna now!!! Thanks---Rich
