Also knocked out a few pens today..
See more from TellicoTurning
I have an outlet in Knoxville that carries some of my pens and other turnings... they wanted some black pens so I did some today... first is a water buffalo horn Baron with Sterling fixtures..
wet sanded through 12000 and then Hut plastic polish.
Second is a Gentlemen's rollerball, water buffalo barrel with an african blackwood cap. Had planned to make the cap water buffalo also, but because of the size of the cap, I blew out the blank when I was drilling...
This last one is all African Blackwood .. the blank was a 1 x 1 x 12 that I got at WC and was labeled Ebony.. there is some brown running through it, so suspect it's not true ebony... I also cut the cap of the pen above fromt the same stick..
Ligget
Bonnybridge, Scotland.
Originally posted by R2
Good match up of materials and well made but for me they are suffering excess girth.:)[:p]
I agree with Arthur about the girth, I like them a little slimmer!
Good work though, lovely kit and blank marriage![:p]
I'm going to post this and may have to eat the words later, but I've had good luck with the Buffalo Horn.. To date, I've never had one crack. I've cracked a few drilling, because I was drilling with a very large bore drill and cutting very close to the limit on the size... the second in the series above was supposed to be a gentlemen's rollerball in all water buffalo horn... the cap is huge and I was almost all the way through the blank when I applied a little too much pressure and wound up with 4 pieces for the cap.... after a few choices words for my Sunday school lesson, I took the ebony and finished the pen.
I drilled each piece with a tub of cold water handy... I would drill for about 1/2 inch and then toss the blank in the water for a couple of minutes... keep the horn cool. Same with turning and sanding... watch the heat... I did a quick dry sand to rough smooth the blank then switch to cold water wet sanding of the tubes to final finish. And the water was cold... I keep a gallon jug of water in the shop for wet sanding... there was ice floating in the jug from the night before.
I was going to post my gloat above... I took the pens up to my outlet to show them... along with 6 others I finished last week... plus the 3 peppermills I show in "other things"... they took them all... over $500 whole sale today.
