hilltopper46
I made this for a friend. It was quite a challenge and I'll be upfront about the fact that I would like to have seen some things go better with it.
I epoxied the brass and blackwood together, but when I drilled it the heat softened up the epoxy and both ends fell apart. I then glued the pieces back together with super glue. I thought if I got one end turned I would be happy and just put plain blackwood on the other end, but even though I had a catch (on the brass) on the top barrel, we got both ends turned, with the application of some more super glue.
Thanks for looking, and comments (and suggestions) are welcome, although, I'm not too sure there will be a next time. :redface:
