4th casting
See more from Drstrangefart
Drstrangefart
Woodstock, Ga. U.S.A.
There's the blank, hot out of the mold
And there it is. I guess I can't really call it a Euro, but I like the shape.
And just in case you're wondering about the 3rd cast:
I decided to give that one to the wife to turn. It may be a while.:beat-up::beat-up:
Drstrangefart
Very nice. What pigments are you using? Mine don't do that.....
I'm using Pearlex. What I did was a horizontal cast. I poured both colors side by side, and used a coat hanger bent at 90 degrees at the last 1/2 inch to stir and drag everything around as it was starting to set. If I understand right, small differences in how you do that make a big difference in results.
