BeeAMaker
First Try with Cocobolo wood. Don't judge me on the design of the pen :smile-big: I'm still getting to know my tools and what I can do with them. I know it's not a conventional shape, I'm just honing my skills before i get serious. So, on with the show (photographer I am not)
I was a bit upset with the fact that the tip of this kit, did not match the diameter of the bushing. I sanded the wood flush to the bushing but you will see in the photo the wood is slightly larger diameter than the tip. I may try my hand at disassembly and put it back on the Lathe. Time to get the calipers out! Is this something I need to watch for or is it mostly limited to the cheaper pen sets?
I also did not take my time sanding it (it was 1am) so I stopped at 600 grit then buffed it with Shelawax. If you look closely you can probably see some cross grain marks. (I left the clip off on purpose)
Thanks!
Thanks!
