Wire Pen - second try with photos
After casting in PR this was the result of top & bottom. It was interesting to see how much 20 ga wire will fit on a pen mill if it is not wrapped the right direction on the tube. It has to wrap turned away from you on top, the same direction as the mill turning when trimming the end. The first one snagged, because it was wrapped under ene to end, and took out 3 ft from in the PR and onto the mill shaft (quickly at that). Each tube took 5 1/2 ft of wire, CA'd ends at the start, middle, and finish on both tubes. I mm'd to 12, EEE'd several times, Novus 2 plastic finished twice, and then Ren waxed. This is for my son who works for an electricial supplier.
