ToddMR
This is a pen kit I never have done before. The directions were sort of confusing in parts with the assembly. It didn't clearly state to press the entire pen together so that it would push the mechanism sleeve higher up into the upper barrel. Also the center band goes up over top of the wood on the upper barrel which was a bit different. Twist one way you get a pen, twist the other and you get a stylus. This is Mexican rose wood finished with 3 coats of Thin ca and 5 coats med ca. Sanded wet MM all the way up.
Thanks for looking!
Thanks for looking!
