spindle travel on drill press ??? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > Southern IN, KY, TN
  Forgot Password
Reply
Old 07-04-2010, 10:52 AM   #1 (permalink)
Photos: 0
Default spindle travel on drill press ???
When buying a drill press to drill pen blanks, what is the recommended spindle travel distance? Obviously the longer travel the better, but will 2 3/8 travel work? Or should I get something that has a 3+ inch travel? I am on a limited budget, so I want to get what is right and yet spend the least amount of money.
indychips is offline   Reply With Quote Top
Old 07-04-2010, 11:02 AM   #2 (permalink)
aggromere's Avatar
Photos: 10
Default
I bought a drill press with 3 inch travel and it was not enough to make some of the longer one piece pens like the zen. If you haven't bought a drill press yet you might want to look into drilling on the lathe. That's what I do. It's not as convenient as a drill press but it works much better. You can also true your blanks on the lathe instead of using pen mills.
__________________
Peter Hall
aggromere is offline   Reply With Quote Top
Old 07-04-2010, 11:34 AM   #3 (permalink)
tim self's Avatar
Photos: 12
Default
Unless you're going to buy a floor press, you will have to live with limited travel of the quill. I've had to learn to live with this issue as have others. Simply put, if the press does not go far enough, you must move the blank up in the vise.
Drilling on the lathe is an excellent remedy but drill bit travel still does not go that far with out moving the tail stock. It's just a more exact way of doing it.
__________________
Tim
tim self is offline   Reply With Quote Top
Advertisement
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
