****Slimline Contest Winners****
davinci27
Franklin, GA
The time has come. I'll post all of the entries soon, in the mean time The votes are counted and the Winners is....
davinci27
Franklin, GA
1st Place and Most Innovative
Mudpuppie
davinci27
Franklin, GA
2nd Place
2nd Place
NewLondon88
David M
Norton, Va. 24273
Okay it is twist , with a twist .....i ll try to explain .
One thing it modifed . The transmission slides into ( when it threaded in) the floting top brass tube ( Not glued in ) .
The tube has about 1/4 in plug that has been drilled the size of refill .
The top is notched for the clip so it does not spin . It his held in place with a cap that has beed drilled .
That is glued in with a peace of cut tube ( Just long enuff to hold it - short ).
The tube with the refill glued in , is slipped into the pen extending through the top . Not cutting the refill till your ready for the top cap that cover the other one that has been drilled .
The top cap is drilled for the refill to be glued on . The one that twist the brass tube. The tube that is not glued in ...The one in the upper part with the refill glued in the plug . Now screw the transmission in , it pushes into the floting tube .
Okay a twisted slimline .......
If i left something out , let me know ill try to explain .
David
NewLondon88
Local Chapter Leader
Claremont NH
Cool! I was dying to post pics of it.
Yes, it's aluminum stock. Used to be a lightning rod. My dad brought his Taig lathe into
the shop for me to try out . and I've been making metal dust ever since.
Did you know a brass cigar pen will tear off your pocket?
New York
Nice pens, innovative work, congrats to you's but us loser's are out to get ya next time hahahahaha (only in my dreams). CINDER_LadyLocket
NewLondon88
Claremont NH
WOOHOOO!!!
I just got a package in the mail from Keith. BEAUTIFUL blanks!
Wild olive, black alder, african blackwood, knob thorn, tambotie,
pink ivory, white stinkwood, sneezewood, silky oak, red milkwood..
.. I'm going to have to take a break from skipratting and resin casting
and actually go back to .. WOOD!!
Thanks so much for these, Keith!
