Plastics/Acrylics with the Pen Wizard
KenV
Juneau, Alaska.
I know I am going to want to machine some plastics/acrylics/polyester pen barrels
And I do some micro machining with plastics and there is a difference between cutting and melting. The cutter geometry is different and the speeds/feeds are different. I have noted that wood generally does not melt and gum up the cutters the same way that plastics do.
Here is a source for some information on milling cutters designed for plastics. The pen barrel materials I am working with appear to be "soft plastics"
http://www.harveytool.com/products/...amily=Plastic+Cutting+End+Mills&category_id=1
or
TinyURL form
http://tinyurl.com/9nf6kn
They have distributors (none in Alaska, but Seattle has several).
When I catch up on the backlog and get my learning curve done with wood, polyester is coming......
ddaudelin
Cape Cod
They all appear to be 1/4" shafts so you'll also need the appropriate tool (Foredom as one choice)...
Dennis
ed4copies
Local Chapter Manager
Racine, WI, USA.
If you use Alternative Ivory, the cheap diamond sets from Harbor Freight work great. I have done at least a dozen this way. With the Dremel at full speed (30000??)
YoYoSpin
Colorado Springs, Colorado, USA
I'm pretty sure that the Crafts Supply version of Alternative Ivory is based on some form of poly resin...cuts and finishes exactly the same. I've Pen Wiz'd polyester resin and TruStone with standard carbide burs and had zero (melting) problems.
